Configures the number of slices used by shared features, such as Layer 7 policy and dynamic ACL.
| slices | Configures look-up stage TCAM resources. |
| shared | Designates setting the shared lookup stage TCAM resources. |
| shared | Sets the shared slice value (range is 0–4). |
| l7GuaranteedPercentage | Designates setting the percentage of shared slice that Layer 7 is guaranteed. |
| l7GuaranteedPercentage | Specifies the guaranteed Layer 7 percentage value (range is 0–100). |
| dynAclGuaranteedPercentage | Designates setting the percentage of shared slice that is dynamic ACL guaranteed. |
| dynAclGuaranteedPercentage | Specifies the guaranteed dynamic ACL percentage value (range is 0–100). |
N/A.
To make changes using this command, you must first disable policy (disable policy).
To view selections made by this command, use the show policy slices command.
The following example configures policy to use 2 slices for shared features and allocate a guaranteed 40% to Layer 7 and 40% to dynamic ACLs:
# configure policy slices shared 2 l7GuaranteedPercentage 40 dynAclGuaranteedPercentage 40
This command was first available in ExtremeXOS 30.5.
